Firmware Status via Python Module
peagacebe
Is it possible to get the firmware version status via API? The statuses are Good, Warning and Critical
No, it's not possible.
michalc
HI @peagacebe ,
Please see relevant API calls below:
To answer your question No, the API calls won't provide the status, but you can compare the current firmware version with the latest stable version. I am sure it is possible to write a script that would print out the status based on the calls above.
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
Yes but the APIs will not show if the firmware is Good, Warning and Critical. 😕
