Filtering on exact match
Guillaume6hat
I discovered (while having an issue), that the result of Filtering was not what I wanted.
I wanted to get all networks having the tag "MYTAG"
So, I used https://developer.cisco.com/meraki/api-v1/#!get-organization-networks , using the tags filter, it worked like a charm.
Then one day, I realized I had more networks than expected. Indeed, it also contained sites with the tag MYTAG-NEW.
It was for future migrations, so bad surprise.
It seems the check on tags is done with "contains".
Should not the call return only exact tag match, with a full string compare ?
Maybe add an option, like for tagsFilterType : tagsFilterMethod, could be "exactMatch" or "contains".
Or by default to be exact match, and using a '*' char if we want to match something else.
Thank you
2 REPLIES 2
MerakiDave
@Guillaume6hat understood, it's basically acting the way you might expect if you were looking at a flex table in the UI and typed MYTAG into the search box.  I'll take a look and submit a feature request if there already isn't one for exactMatch versus contains.
You're right. That is also not perfect 😅
If there could be an option on the dashboard to have an exact match as well, like putting in double quotes for example, that would be awesome.
