Error with API call getOrganizationApplianceTrafficShapingVpnExclusionsByNetwork
Ozzyraven
I am having some serious trouble getting the vpn exclusion rules for a single network or few in my organization.
I keep getting the error networkIds must be an array and I have tried any suggestion I have found to fix with no better results.
I am regularly using v1 and postman API v1.58, your help would be appreciated.
See example below:
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add("Accept", "application/json")
$headers.Add("Authorization", "••••••")
$response = Invoke-RestMethod 'https://api.meraki.com/api/v1/organizations/0198272/appliance/trafficShaping/vpnExclusions/byNetwork...', 'L_00011222'] ' -Method 'GET' -Headers $headers
$response | ConvertTo-Json
Oren
Arrays in REST calls have an annoying syntax. Did you try this?
Oren
Ozzyraven
Hello, thank you. that worked perfectly. here is the code that worked for me for reference
# Set up headers correctly for Meraki API authentication
$headers.Add("Content-Type", "application/json")
$headers.Add("X-Cisco-Meraki-API-Key", "YOURAPIKEY") # Replace with actual API key
# Define the API URL with proper query parameters
$networkId = "L_XXXX"
$organizationId = "XXXXXX"
$apiUrl = "https://api.meraki.com/api/v1/organizations/$organizationId/appliance/trafficShaping/vpnExclusions/b..."
# Make the GET request
try {
$response = Invoke-RestMethod -Uri $apiUrl -Method 'GET' -Headers $headers
$response | ConvertTo-Json -Depth 3 # Convert response to JSON format for readability
} catch {
Write-Host "Error occurred: $_"
RaphaelL
networkIds[]=xxxxxxxxx  should be the parameter
