- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Efficient way to monitor switchports
I want to be able to fetch switchport data via the API similar to how I would with SNMP, for the 'usual' metrics:
- Speed/Duplex
- Operational / Administrative Status
- Throughput
- Error packets / packet types.
All of this is exposed via the API, but to the best of my knowledge, I have to make three separate calls per switch to retrieve all of this info. This isn't a problem, until the rate limiting kicks in. I do have backoff logic in place, but apparently it's not always cutting it.
This is what I'm doing, does anyone know of a way to reduce the calls?
// Retrieve interface packet counts for the switch.
query('/api/v0/devices/' + device.serial + '/switchPortStatuses/packets?timespan=' + TIMESPAN)
// Retrieve interface usage counts for the switch
query('/api/v0/devices/' + device.serial + '/switchPortStatuses?timespan=' + TIMESPAN)
// Retrieve interface statuses for the switch. Cannot use the above call because it blanks out 'status' values when a timespan is applied.
query('/api/v0/devices/' + device.serial + '/switchPortStatuses')
Solved! Go to solution.
- Labels:
Dashboard API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No way to reduce the API calls sorry.
The latest Python SDK does support rate-limiting.
For node.js I use bottleneck to manage it automatically.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
