i everyone, i need disable 2 options in the network with API, General -> Traffic analysis ->
and Wireless -> Firewall & traffic shaping -> RA Guard
is it possible or not?
Solved! Go to solution.
https://developer.cisco.com/meraki/api-v1/#!update-network-traffic-analysis
RA guard would likely end up a parameter here, but if it's supported, it's not shown in the docs https://developer.cisco.com/meraki/api-v1/#!update-network-wireless-ssid
I'd raise a Support case around this
thank you i didnt see the option disabled thanks a lot, and maybe i need the support case T_T
