Dev hub issue
Adrian4
Dev hub issue
Happy New Year everyone,
I am trying to use the Dev Hub API to check the API requests for my org to troubleshoot an issue but the Auth header seems to be greyed out so I ant put my key in 😞
I tried just adding a new Auth field but it didn't work. Any idea what the issue is?
https://developer.cisco.com/meraki/api-v1/get-organization-api-requests-overview/
Add 'X-Cisco-Meraki-API-Key' as another Header
I'll add that this might only work temporarily as the goal is to not allow user's API keys to be entered into the site for security reasons.
Ryan / Meraki Solutions Engineer
5 Replies 5
Ryan_Miles
I believe this is due to what's mentioned here under point #4
https://developer.cisco.com/meraki/whats-new/2023/#highlights-1
I can see point 4
API interactive Documentation update
  • Improved security by providing test keys to run request against the API and restricting user sensitive API keys to be pasted in the documentation.
but i cant see any actual information about it - if they are using some test keys - how come it doesn't work? Is there something specific i am supposed to do?
cheers
And the test key idea if to only allow certain calls to work against the sandbox org. Example this call https://developer.cisco.com/meraki/api-v1/get-organizations/
ah, cheers
