I usually add some backoff and retry logic around API calls that retrieve information, to cope with transient errors.
We pull a lot of data from different orchestrators including Dashboard, as these errors occur fairly often (at the volumes we operate at).
If it used to be ok, but the issue is new and persists, consider opening a case with support.
