- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Conflicting Traffic values between GUI and API
Hi I'm trying to extract the current bandwidth of a given MS port.
For this I'm using the API call:
https://api.meraki.com/api/v1/devices/{MSserialNumber}/switch/ports/statuses?timespan=86400
On the UI I get:
On the API output I get following JSON for that same port:
-> the usageInKb seems to match, but the trafficInKbps doesn't
1. What's the timespan (currently 86400) to use to get the most recent trafficInKbps of a given switchport?
2. How comes these values are different between UI and API?
3. Is there a more accurate way to get the current BW used on a given port over API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This might be a matter of conversion.
1Mb = 1,024 Kb (not 1,000).
1Gb = 1,024 Mb = 1,048,576 Kb.
Therefore 1,051,718,192 Kb = 1,003 Gb.
Does it make sense?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Oren, indeed the usage corresponds correct, but the Traffic numbers are way off
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the clarification.
Traffic is defined as "A breakdown of the average speed of data that has passed through this port during the timespan."
While Usage is defined as "A breakdown of how many kilobytes have passed through this port during the timespan."
Reference: https://developer.cisco.com/meraki/api-v1/get-device-switch-ports-statuses/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Oren,
Thanks for pointing out, I kind of missed that. It's somewhat confusing as the dashboard URI timespan is similar as the API but showing different values:
https://n170.meraki.com/Org/n/key/manage/nodes/new_list/number/ports/18?timespan=86400
but understood, I overlooked this in the description.
This means I need to find another way to get the latest speed of that port
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I probably would have missed it too, unless I was looking for it.
By latest speed, do you mean 100M/1G/10G/etc’?
The getDeviceSwitchPortsStatuses operation will get you that (there’s a new org-wide version coming out later this week).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm looking for the API call to readout the exact value as you can see on the UI. To read out every 10s to get the actual speed at that moment
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I understand. The real-time traffic value you’re looking for is not currently available via API.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Real time data is not available via the API.
I'm doing something similar to you but for historical metrics via Prometheus and I went with a timespan of 900s (15 minutes) that I have noticed is the minimum that always give me a reply as I have noticed that using a timespan of 12/13 minutes or lower almost always replies with all 0.
For live monitoring the only way to go is the Dashboard, but for historical metrics I think that the average over 15 minutes could be good enough.
