Client Events API call - oldest events first or am I not parsing correctly?
--Updating to include actual timestamp from response--
I am making an API call using this structure:
"GET/networks/[networkId]/clients/[id_or_mac_or_IP]/events"
In my responses, the 'ocurredAt' is in the form:
1531233271.311001
I am assuming that this is an Epoch timestamp with extra precision after the '.' Based on that assumption, I  am running a timestamp conversion using only the integer before the '.'
When I do this, my dates are 6 months old. Am I not parsing this correctly or does the events endpoint return data oldest -> newest?  If so, is there a some parameter that will  give me newest first?  I don't see a timespan option in the API docs.
As always,  all help is appreciated.
Accepted Solutions
Re: Client Events API call - oldest events first or am I not parsing correctly?
The endpoint /networks/[networkId]/clients/[id_or_mac_or_ip]/events includes parameters for startingAfter and endingBefore.  The documentation warns against client applications setting these parameters.
When you make a request to this API, the response includes a Link header.  For example:
Link: <https://n000.meraki.com/api/v0/networks/N_1234567890/clients/abc12345/events?startingAfter=1476908909.0>; rel=first, <https://n000.meraki.com/api/v0/networks/N_1234567890/clients/abc12345/events?startingAfter=1517256994.237001>; rel=next, <https://n000.meraki.com/api/v0/networks/N_1234567890/clients/abc12345/events?endingBefore=1548874564.0>; rel=last
You can use the values of startingAfter or endingBefore in the Link header to work your way through all events for a given client.
If you want to throw caution to the wind (as I might have done), you could try adding the endingAfter parameter to your original request and including the current unix epoch.
Otherwise, the API seems to return the oldest events.
8 REPLIES 8
How are you performing the timestamp conversion?
When I convert 1548864847, I get Wednesday, January 30, 2019 11:14:07 AM GMT-05:00
Should be a unix timestamp indeed. I can't double check on my network as I get a timeout for that specific GET at the moment. I checked the similar /securityEvents and the ts there gives me a correct time.
1548864847 equals to January 30th, 2019. How are you doing the conversion?
I am using the datetime module in Python 3.7,  Here is the parse and conversion:
timest = (str(i.get('occurredAt')).split('.'))[0]
newtime = datetime.datetime.fromtimestamp(int(timest))
C:\Users\brecht.schamp>python
Python 3.5.4 (v3.5.4:3f56838, Aug  8 2017, 02:17:05) [MSC v.1900 64 bit (AMD64)]
 on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import datetime
>>> timest = "1548864847"
>>> print(newtime)
2019-01-30 17:14:07
Sorry, the timestamp I used in my question was today's time. I was using that to illustrate the "form".  Actual data is more like:
1531233271.311001
Thank you for investigating and the detailed confirmation.
I did attempt to add the "startingAfter=<yesterday's timestamp>" to the client request query string.  For my test, it only return events "after" the supplied timestamp. This will work for my use case.  Thanks again to all for the help.
