Changing Scheduled Availability using API
pfisterfarm
Just browsing
Is there a way to change the SSID scheduled availability under the API?  I have a particular SSID that's the same on 30+ networks in the Dashboard. It needs to be unavailable for a given time range during the week. Occasionally, it needs to be on for a particular week day or range of days. Editing the schedules by hand is way too time consuming. Can the schedule be set in a python script?
If I need to add and remove tags from the APs and enable the SSID based on the presence of those tags, that should work if there is no alternative currently.
Maybe it will help you.
https://developer.cisco.com/meraki/api-latest/update-network-wireless-ssid-schedules/
Do you have an updated link? This one is not working. I would like to use the API to change the scheduled availability of specific SSIDs. Thank you.
pfisterfarm
Just browsing
Yes! That's exactly what I was looking for. Thank you!
