- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Bulk changes to multiple network devices
I see there is a JSON script for updating the attributes for devices but it only allows for one at a time. Does anything exist for updating tags or any attribute with one api call?
It also seems as though to update one attribute , it requires all attributes to be included in the script. Can someone please advise?
Solved! Go to solution.
- Labels:
Dashboard API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Below should get you what you want for updating address, tags, etc. This scrip assumes you don't know your org Id and the network Id associated with each serial number. If you know that information, you can modify the script to suit your needs. To get your serial numbers into a list, you could read through a file and populate it that way also.
The firewall rules would follow the same concept.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You might need to give a specific example.
Here is an example of one API call and it lets you update lots of things at once.
https://dashboard.meraki.com/api_docs/v0#update-the-attributes-of-a-device
Does it really make that much difference making muliple API calls?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes i have already explored that API call. What i am looking to do is to update lets say at least 10-25 devices (switches or APs) at once in the same network with new tags and or new address. This particular API call appears to only let you do one serial number at a time and requires all the attributes be completed.
Does that give a clearer picture?
It makes a difference because from what i am understanding i would have to change out the serial # for each call when i would like to just do one push and it pushes the "new tag" and/or "new address" to all the devices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm pretty new to the API myself so this may not be a comprehensive answer. I'm doing something similar, renaming APs and so far I have been able to change 15 at once using that API call and Collection Runner in Postman.
Here's what I did:
*Install Postman and the Meraki Dashboard API Collection (the collection is optional, you can just type this in)
*Create a new request in Postman (either make environment variables for your API key, the baseURL, and networkId or just fill them in). Here is what mine looks like.
{{baseUrl}}/networks/{{networkId}}/devices/{{serial}}?name={{name}}
*Create a .csv file with two columns. One has header "serial" and the other has header "name"
*Click Runner in Postman to open that window. Choose the request you created above and use Select File to choose the .csv file
*Click Run Start
*Check the Meraki dashboard to see that it worked.
My command only updates the name, so any variables you don't change stay the same. You should be able to change the name variable to be your tag variable instead and add another one for the address.
Here's a link to the Postman variable documentation that may help with adding another variable. https://learning.postman.com/docs/postman/variables-and-environments/variables/
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
i just first with your serial number but that doesn't work and neither with the tag inserted as a variable as well.
https://{{shard}}.meraki.com/api/v0/newtorks/{{network_Id}}/devices/Q2KD-XXXX-XXXX?name=AP001
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi
Using Postman is one way of doing it, however If you use Python and the Meraki API call, you can browse through that network, obtain all serials of the devices and the change the objects you want.... Done that several times already with my networks here.
here is an example of the things we use here. (identing is gone with cut and paste)
def Add_Network_Device(def_network,def_serial,def_site_code):
# First check if device is already in network
device_there = 0
my_network_devices = dashboard.devices.getNetworkDevices(def_network)
for my_network_device in my_network_devices:
if def_serial == my_network_device['serial']:
print ("device ",my_network_device["model"],"with serial",def_serial,"already added")
device_there = 1
if device_there == 0:
print ('Adding ',def_serial,' to netowrk id : ',def_network)
try:
response = dashboard.devices.claimNetworkDevices(def_network,serial=def_serial )
print (response)
except:
print ("Failed to add device")
quit()
my_device = dashboard.devices.getNetworkDevice(def_network,def_serial)
model_type = str(my_device['model'])
if model_type[:2] == "MX":
def_site_code += "-FW1"
elif model_type[:2] == "MS":
def_site_code += "-SW01"
elif model_type[:2] == "MR":
def_site_code += "-AP01"
param = {}
param['name'] = def_site_code
try:
response = dashboard.devices.updateNetworkDevice(def_network,def_serial,**param)
print (respons)
except:
print ("Cannot update ")
print ("Name is : ",def_site_code)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you looked into Action Batches?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have played with those as well, but i am trying to familiarize myself with the best approach either python or utilizing postman. Anymore advice would be much obliged.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To be honest, I don't sue Postman so I can't comment on that. If you want to update any attribute of a device, you have to do them one by one as the API identifies devices by serial number. You could do a simple Python loop to take care of this for you. You don't have to update all attributes, you can only update the ones you want. If you have, say, 100 devices in your dashboard and only want to update 10-25 devices, how do you identify those 10-25 devices? By name, tag, serial number, etc.?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
By serial #, that is really what i am looking for. If i want to update an address or tag for a certain set of devices within a network then i would like to use a loop to hit say 5 or more devices.
Or another would be if i want to add multiple firewall rules then i would like to do this with loop within python for example by the network id in the meraki dashboard.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Small Function to write all serials of your network to an xls file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If your API key is tied to multiple orgs, this will only get the devices of the last org it pulls back in the list. To get all serials in all orgs, you would need to put everything in the "for org in my_org: loop".
