Bugfixes rolling out for getOrganizationWirelessRfProfilesAssignmentsByDevice
John_on_API
Meraki Employee All-Star
Hi folks,
Just FYI that we've identified two issues with this operation and are currently remediating them. However, if your application does not consume the "meta" object of the response body then you are affected by neither the bugs nor the fixes.
  1. The "meta" portion of the response body doesn't match the intended, correct documentation. If your application is expecting the meta.items object documented in the response body, then this fix will restore functionality to the operation.
  2. The item counts in the "meta" object of the response body do not take into account query parameters. For example, filtering to a specific serial should result in the items counts reflecting accordingly.
0 Replies 0
