- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Bad request: There was a problem in the JSON you submitted
I've written a function using Google Apps Script to create an organization in Meraki but received above error saying there's a problem in the JSON.
I was able to GET data from Meraki but unable to PUT data using below format.
Any advice why this is happening?
function createOrg(orgName)
var org =
"name": orgName
var URL = "<a href="https://api.meraki.com/api/v0/organizations" target="_blank">https://api.meraki.com/api/v0/organizations</a>";
var params =
headers:
"X-Cisco-Meraki-API-Key": settings.apiKey,
"Content-Type": "application/json",
"Accept": "*/*"
method: "PUT",
payload: org,
muteHttpExceptions: true
var response = UrlFetchApp.fetch(URL, params);
Logger.log(response);
Solved! Go to solution.
- Labels:
Dashboard API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A few things. The create org call is supposed to be a POST instead of PUT.
I noticed that you need to apply a function to the payload:
payload: JSON.stingify(org)
Replace the baseURL with the actual shard you are on. Google script does not seem to follow the redirect. E.g. https://n248.meraki.com/api.... instead of https://api.meraki.com ... More info about that issue here: https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API... (look for the section about redirection)
So this works for me:
var org =
"name": "Google Apps Org 2"
var URL = "https://<myshardid>.meraki.com/api/v0/organizations";
var params =
headers:
"X-Cisco-Meraki-API-Key": "<myAPIkey>",
"Accept": "*/*"
method: "POST",
payload: JSON.stringify(org),
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
var org =
var params =
headers:
"Accept": "*/*"
method: "POST",
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@BrechtSchampthank you so much for your advice, I was able to create the organization successfully.
