Automating site deployments using Network and Switch templates with Ansible or Python+API
WojtekMitus
Hello, we are evaluating using Meraki solutions to deploy networks in office buildings of various sizes, and i would like to do deployments entirely in IaC model, leveraging Network Templates and Switch Templates to reuse standarized configurations as much as possible.
As i was not able to find a guide for such deployments, i would like to ask few questions here.
1. What would be proper workflow for defining and applying reusable configuration in dashboard? I'm assuming:
  - Create Network Template and configure all template configurations according to the needs
  - Create and configure Switch Templates inside a Network Template, which could be attached later to real devices
  - Create a Network from a Network Template - an actual site
  - Claim devices into the Network
  - Attach switch templates to devices, define and build switch stacks in the actual deployed Network (there are no stack templates, right?)
  - Configure exceptions on actual switch ports which would have to differ from applied templates
  Is this correct?
 2. Currently i am trying to map particular dashboard functions to appropriate Ansible modules which would configure that option, and i am not able to find a module for creating a Switch Template inside a Network Template, and configure ports in this template. Which module allows to do this?
 3. The same goes for API documentation, i am not able to find which API call would create Switch Templates in a Network Template and configure the ports in newly created Switch Template. I guess there is an API for that?
Thanks,
Wojtek
2 Replies 2
VivekT
As far as I know ,currently, Meraki's API does not provide specific endpoints to directly create or manage Switch Templates within Network Templates. The Dashboard API is more focused on device and network-level configurations rather than templates.
Template Management:
  • You can create and manage templates via the API using the /organizations/{organizationId}/configTemplates endpoint.
  • Example: Creating a new template or binding a network to a template.
    Switch Ports Configuration:
    • The /devices/{serial}/switchPorts endpoint lets you configure ports, but this applies to individual switches in deployed networks rather than templates.
      Suggestions and Alternatives
      1. Manual Template Setup:
        • Since templates must be set up manually, you can focus on using APIs or Ansible modules to automate device-specific configurations post-deployment.
      2. Scripted Automation:
        • For now, use scripts or automation workflows to configure networks/devices systematically after applying templates.
      3. Hybrid Approach:
        • Combine manual template creation with automated per-device configuration using Ansible or Python scripts to bridge the gap.
      Please let me know if it helps.
VivekT
      3. Hybrid Approach:
