I'm looking at making a script to setup new networks with as little effort as possible.
One of the first things to do after creating the network is add two MX units (warm spare config).Is this the correct endpoint to do that and to set their ip and subnets?
POST/networks/{networkId}/appliance/warmSpare/swaphttps://developer.cisco.com/meraki/api-v1/#!swap-network-appliance-warm-spare
Thanks!
Solved! Go to solution.
thanks! useful stash.
After digging through looks like this one is correct POST /networks/{networkId}/devices/claim
just found this one that may be the correct one instead?POST /networks/{networkId}/devices/claimhttps://developer.cisco.com/meraki/api-v1/#!claim-network-devices
Take a look at this:
https://github.com/meraki/automation-scripts
https://developer.cisco.com/meraki/build/automation-with-python-api-lab/
