Action Batches for monitoring APIs
revanth
It seems Action Batches are supported for monitoring APIs such as /appliance/uplink/statuses, /devices/uplinksLossAndLatency. Is my understanding true?
Monitoring APIs tend to be more frequent and can hit API limit, trying to see if I can leverage action batches to create a batch with monitoring all interested monitoring API end points. Any suggestions here?
2 REPLIES 2
To the best of my knowledge, they are not.
You can get the status of all the devices at once using APIs like:
https://developer.cisco.com/meraki/api-v1/#!get-organization-uplinks-statuses
https://developer.cisco.com/meraki/api-v1/#!get-organization-devices-uplinks-loss-and-latency
you are right @PhilipDAth , it seems monitoring APIs are not supported for action batches. It took me a while to find this reference on supportive resources for actionBatches API. It would be nice to add a link directly into the documentation https://developer.cisco.com/meraki/api-v1/#!create-organization-action-batch for supported resources.
Supported resources for action batches are documented in a separate location https://developer.cisco.com/meraki/api-v1/#!action-batches-overview/details
