API to toggle on GCMP 256 in Wireless > Access Control
jacfraze
Hey, forgive me if this has been asked before but.
Is there a way to programatically toggle on
WPA encryption = WPA3
802.11w = Required (reject unsupported clients)
AND
WPA3 Cipher Suite = GCMP 256
at the same time?
We are able to do WPA3 + 802.11w but I cant seem to find an API to enable GCMP 256 in the "Advanced WPA3 settings(Cipher and AKM suite settings)"
jacfraze
I worded this question poorly. What I was really asking for is if there was an API to toggle on GCMP-256. Because it isn't mentioned in the API documentation for the the wireless SSID settings and the payload required isn't part of the payload example body.
https://developer.cisco.com/meraki/api-v1/update-network-wireless-ssid/
I did however manage to toggle WPA3 Enterprise, 802.11w and GCMP-256 on programmatically at the same time by sniffing the dashboard API PUT requests via devtools after toggling it on in the dashboard.
This enabled me to write a script to set WPA3 enabled, 802.11w enabled, GCMP-256 toggled on.
payload:
wpa3Configs : {cipherGcmp256: true, wpa3Akm8: true, wpa3Akm24: false}
I believe GCMP 256 requires you to use WPA3-192 (and not WPA3).  Also note that WPA3-192 only supports EAP-TLS, and requires certificates using 4096-bit RSA keys or better.
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/WPA3_Encryption_and_Configuratio...
KarstenI
It's not that easy with GCMP-256 ...
For IEEE 802.11be GCMP-256 support is mandatory ("An EHT RSNA STA shall support GCMP-256"). I don't find any hint in the standard that differentiates between SAE and 802.1X here.
But GCMP-256 was in the standard before, and the usage is allowed. The WPA3 specification doesn't require it, but defines that it can be enabled for both WPA3-Personal and WPA3-Enterprise.
And while the WFA disallows any other ciphers for WPA3-192, the standard would allow CCMP-256 for the same setting.
And for the certificates for WPA3-192, 3072-bit RSA is enough. But I would go for EC certificates with 384 bits.
If GCMP-256 can not be enabled in a specific combination, it's likely the decision of the vendor to do it "this way". The Catalyst 9800 has the same "problem".
jacfraze
payload:
