API integrations - unsupported base Uniform Resource Identifiers (URIs)
pfoster
Anyone have insights? I've had a case open with Meraki for over a week and still no luck. I'm in the US, and got a message that some of our API integrations need to be updated.
Old API - https://nxxx.meraki.com
Supposed new API - https://api.meraki.com/api/v1/
Tried every variation of the above, still no luck.
I'm not versed in API's and such, just trying to get it working. Every time I paste what I thought would be the correct new URL, and test, it fails.
I've tried the following
https://api.meraki.com/api/v1/organizations/nxxx
Anyone have any insights?
6 Replies 6
Oren
Meraki Employee All-Star
Insights to what? Which script is making API calls to an unsupported URI, or how to update it?
First, you'd need to verify which APIs you use and then check not only the initial URL, but also validate the corresponding API for the function you're using.
This would be a good place to start.
https://developer.cisco.com/meraki/api-v1/introduction/#meraki-products
sungod
Your "Old API" is pointing at a specific shard nxxx, I don't think referencing a shard has ever been advocated as the base URI (other than as a workaround for some problems a while ago), it generally works, but it's not the proper way.
In most parts of the world, every API request should begin with the following base URI:
...this has been the standard for many years now.
The recent change is that for organizations hosted in the following dashboards, you need to specify the respective base URI instead:
Dasboard/Country                               URI
Canadahttps://api.meraki.ca/api/v1
Chinahttps://api.meraki.cn/api/v1
Indiahttps://api.meraki.in/api/v1
United States FedRAMPhttps://api.gov-meraki.com/api/v1
What failure code(s) are you getting?
pfoster
Hi All, so I was able to get it working. I replaces https://nxxx.meraki.com with https://api.meraki.com and it worked. I would have got this working sooner, but after the initial testing I realized my firewall rule (Palo Alto) was URL based and whereas I was permitting nxxx.meraki.com I was blocking the new link. BTW, the app I was working with was NetBrain. I have API integrations with NetBrain, ServiceNow, SolarWinds, StatSeeker.
Oren
I'm glad to hear. Thanks for the update!
Are you able to post the complete URL you are using, or show the code that is forming a full URL (make sure you don't show any API keys)?
