API for number of failovers
tjh188
Good Morning guys,
Is there an API for the number of WAN failovers that occurred in a 24 hour period?  I have the MX68 with 2 WAN ports with the ISP plugged into INT 1 and a Cradlepoint device with a cell SIM in INT 2.  I would like to know how many failovers happen within a time frame.  I have over 750 MX68s on our network.
2 REPLIES 2
You can monitor the status of the interfaces, but not how many times failed-over from one interface to another. Have you tried monitoring via SNMP?
JasonM
There is an event log event type for Primary Uplink Status Change that you could use. I assume that your primary interface is WAN1. An event will be generated upon failure and again for when it is restored. The event type to filter by is failover_event.
https://developer.cisco.com/meraki/api-v1/#!get-network-events
