API calls for Switch & Access Points CPU & Memory utilization
AJAY2
Hi, can someone please help me with the API calls for Switch & Access Points CPU & Memory utilization? Thank you !
Have you checked this?
https://developer.cisco.com/meraki/api-v1/get-organization-wireless-devices-system-cpu-load-history/
https://developer.cisco.com/meraki/api-v1/get-organization-devices-memory-by-device/
https://developer.cisco.com/meraki/api-v1/get-organization-devices-system-memory-usage-history-by-in...
Unfortunately, there is no API available to collect this information.
AJAY2
Oops! Okay. I see the CPU & Memory for APs on the dashboard however could not find the correct APIs for same.
AJAY2
Yes, I did few months back but was not satisfied with the output then. I thought Cisco would have come up with simpler API response. Anyways let me try to incorporate same and observe the outputs.
