API call to move AP to another Vlan
cirizan
How would I move multiple Access Points, to a different Vlan for management purpose, using API calls ?
cirizan
Well, this is to change the native Vlan on the switch port. Thanks.
6 Replies 6
NolanHerring
You are going to want to update the switch port VLAN basically:
{{baseUrl}}/devices/{{serial}}/switchPorts/{{portNum}}
"name": "test from Postman",
"tags": "API",
"enabled": true,
"poeEnabled": true,
"type": "trunk",
"vlan": 1,
"voiceVlan": null,
"allowedVlans": "all",
"isolationEnabled": false,
"rstpEnabled": true,
"stpGuard": "disabled",
"accessPolicyNumber": null
Nolan Herring | nolanwifi.com
TwitterLinkedIn
cirizan
NolanHerring
Do you mean when you go to Switch>Switch Settings>VLAN Configuration>Management VLAN ?
Not sure if there is an API to change that, or at least I don't see one.
TwitterLinkedIn
cirizan
I meant changing the management vlan from the AP settings itself. Me as well, don't see any APIs to change that. So, your solution is the best at the moment.
NolanHerring
So the VLAN the trunk port is configured for will basically be the 'management' VLAN in the sense that the AP will grab an IP from that VLAN.
This below requires 26.x code. Have to contact support to have it enabled.
No API method for this that I know of.
https://documentation.meraki.com/MR/Other_Topics/Alternate_Management_Interface_on_MR_Devices
TwitterLinkedIn
cirizan
Thanks Nolan
