API call to directly retrieve WPA2 vs WPA3 authentication per wireless client
SteMeDi
Hi everyone,
I am currently working with the API and I am trying to determine the actual authentication method used by wireless clients - specifically distinguishing between WPA2 and WPA3 in WPA3 Transition Mode.
Is there any API endpoint that directly exposes the negotiated authentication/security method per wireless client session?
Thanks!
5 Replies 5
The current Dashboard API does not expose whether a client connected via WPA2 or WPA3 when Transition Mode is enabled. That level of detail is visible via management frames, but not surfaced in the API.
SteMeDi
Thanks for your answer, @alemabrahao.
WPA3 Transition mode is a train wreck.  I'd avoid using it if you like reliability.
SteMeDi
Hi @PhilipDAth, Can you please explain why? thx 🙂
Really bad client driver compatibility.  You'll frequently get clients who can't connect or don't roam properly.
