Hi there ,
I'm using the new API call for switch Port status but I'm always getting a HTTP 502.
I have also tried the console / debug call from https://developer.cisco.com/meraki/api/#/rest/api-endpoints/switch-ports/get-device-switch-port-stat... but I'm still getting 502.
I have tried with switches from MS11.22 to MS11.30 and still no luck.
Any clues before I open a ticket ?
Thanks.
Hi @RaphaelL,
Can you post the code you're using to make the call (remove the sensitive bits). It'd be pretty hard to guess with the information provided.
I'm using the link https://developer.cisco.com/meraki/api/#/rest/api-endpoints/switch-ports/get-device-switch-port-stat... to test the call. You only need your API key and a valid serial number from your Org.
If you try it using the Postman collection, do you still get 502? I just tested across a couple of shards, and successfully got returns.
Trying to rule out something weird going on with your cURL processor.
Samething. Tried with Postman and still get a 502.
Only 2 calls are failing at the moment : switchPortStatuses and switchPortStatuses/packets.
Are they dependant on a specific firmware version ?
It is not firmware dependent. I have tested both APIs, switchPortStatuses and switchPortStatuses/packets, and I can confirm that they are working.
What shard are you on? We've seen problems before where most shards were okay but a couple were being difficult, on other calls.
I have access to a number of shards with switches on, so it's possible that I can test on the same shard as you.
@Nash I tested on n80 and n189, both works. I just use Postman for testing.
Sorry , I was out of the office.
This org seems to be on n238.
I have access to a lot of shards also, I tested on n216 and it is working. I think I'm going to open a case about it.
