Hi ,
I'm trying to find this exact setting with the API :
I can't find it.
It would be way easier to find endpoints if they would match the dashboard description.
Eg : getNetworkApplianceTrafficShapingUplinkBandwidth is not a valid dashboard section. It should be UplinkConfiguration just like getNetworkApplianceTrafficShapingUplinkSelection is a valid section :
I feel like the whole dashboard page TrafficShaping is scattered into so many api endpoints. Way too confusing for no reason.
6 dashboard section :
Uplink configuration
getNetworkApplianceConnectivityMonitoringDestinations ( doesn't follow the name scheme + named Uplink statistics )
Uplink selection
getNetworkApplianceTrafficShapingUplinkSelection ( missing WAN failover and failback behavior on templates ... )
SD-WAN policies
getNetworkApplianceTrafficShapingUplinkSelection ( parts of the result is from 2 sections. Confusion +1 )
getNetworkApplianceTrafficShapingCustomPerformanceClasses
Local internet breakout
getOrganizationApplianceTrafficShapingVpnExclusionsByNetwork ( only a org-wide call ? )
Global bandwidth limits
getNetworkApplianceTrafficShaping ( doesn't follow the name scheme )
getNetworkApplianceTrafficShapingRules
I might be missing some due to the confusion.
