API Key Permission details required
Mytestcase
Hello Team,
I have access to Meraki dashboard with Read only permission. when i create API Key for my Account.
I want to know my Generated API key is having read only permission or it can perform Write Action also using API Calls ?
Please provide updates.
Thanks and Regards,
Sateesh Billur.
Technical Lead, SME for Meraki Networks, Technical Manager
JamesT91
Cisco Meraki Dashboard API - Cisco Meraki Documentation
API key permissions mirror that of the account that created it - so in your scenario, read-only.
6 Replies 6
JamesT91
Mytestcase
Thanks a lot James
Mytestcase
Hello James,
I wanted to know if i do API call for reading Organization details and Network and Device details is logs is updated in Meraki dashboard stating that so and so time API call made to pull the records. It would be great to know frow where we see the logs
Thanks and Regards
Sateesh Billur.
JamesT91
They are - take a look under Organization > API & Webhooks. Use the 'download detailed logs' button and you should get what you're after.
Mytestcase
Thanks a lot James..!!
JamesT91
You are most welcome 😊
