- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
API - Handling dicts and pagination
Hi ,
Some recent changes to getOrganizationSwitchPortsStatusesBySwitch have broken my code and pagination.
I don't condider my self great with Python or programmation in general so bear with me.
The output is now a dict instead of a list. How do you handle that output when receiving multiple pages ? Dicts were easy , you simply do final_list = final_list + new_list at every page and it grows into a big list voilà !
With dicts I can't do that.
Example of the output :
{ "items": [ { "name": "xxxxxxxx", "serial": "xxxx", "mac": "xxxxx", "network": { "id": "xxxxxxxxx", "name": "xxxxx" }, "model": "MS225-24P", "ports": [ { "portId": "1", "enabled": true, "status": "Connected", "isUplink": true, "errors": [], "warnings": [], "speed": "1 Gbps", "duplex": "full", "securePort": { "active": false, "authenticationStatus": "Enabled" }, "spanningTree": { "statuses": [ "Forwarding", "Is edge", "Is peer-to-peer" ] }, "poe": { "isAllocated": false } }]
The only "solution" ( which is probably disgusting ) is to get the list of items and put them in a list.
Using the Meraki Python SDK is not an option in my case and I'm not debating why, that's not the point.
Thanks ! 😊
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @RaphaelL,
The getOrganizationSwitchPortsStatusesBySwitch is a beta operation which is going through changes to improve performance. That's for the breaking change part.
Regarding the format, you can easily adjust the code you're using today.
new_list = response['items']
Then,
will work as it has before.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Pulling the items out of the dictionary and adding to a list isn't the worst solution, honestly. It depends on what you're wanting to do with it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @RaphaelL,
Then,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Exactly what I did this afternoon. I thought this was a "easy fix" on my end and everytime I do a easy fix it ends up being a dump fix haha !
Will it be a "norm" to return the output in a dict with a list "named" items ?
