'429 - Too many requests' status code is reoccurred.
Gwangjin
I inquired about the same problem a while ago and solved it then.
But the same problem is happening again today.
(Previous inquiry details)
- When call 'Meraki Dashboard API' in the company, '429 - Too Many Requests' occurs.
- But it's called normally at home. (status code : 200)
So I checked the 'Get Organization Api Requests Overview' API and the results are as below.
There's only two case in a minute.
And I also called the 'Get Organization API Requests' API and the results are as below.
There were only two APIs called.
I kept the Rate Limit, but why is '429 - Too Many Requests' occurring?
What else should I check?
Please someone let me know.
regards Gwangjin
I didn't open a support case as I'm not affected.
I ment : If I were you, then I would open a support case.
3 REPLIES 3
Greenberet
That doesn't sound right. I would open a support case and let the support team check this.
Greenberet,
Is there anything you got from the support team?
Can you share it with me if there is any progress?
