topology
meraki2champion
topology
hello everyone i have logged in to my dashboard i went to topology but i didn't see any display of how my devices are interconnected what could be the problem?
8 Replies 8
Roska
You don´t have combined network? You don´t have any MS in your network?
@Roska  yes i have ms in my network but i don't have combined network
In combined networks, topology shows an integrated Cisco Meraki network that has MX Security Appliances, MS Switches, and MR Access points. Squares represent MX security appliances, rectangles represent MS switches, stacked rectangles represent MS physical switch stacks, and circles represent MR access points. Non-Meraki equipment is also detected if it is one hop away (and will appear as an empty diamond); depending on the protocols supported by a non-Meraki device, the topology view may be able to discern LLDP data like model type, IP, and manufacturer. Meraki devices in a different network will be denoted by blue diamonds.
Source:
https://documentation.meraki.com/MS/Monitoring_and_Reporting/Network_Topology
You need a combined network.
In an non-combined network it will only work within switches interconnected
kYutobi
As @Roska had asked what's in your network currently?
Enthusiast
@kYutobi  every device is in separate network
Why is every device in a separate network? I wonder what reasoning or layout you have to want that as a setup?
Nash
Depending on the age of setup, combined networks weren't always a thing, @DillonofAnch17. I've run into folks who habitually set things up as though combined networks still aren't a thing, even though Meraki released that... :checks notes: in 2013.
One can combine networks together relatively easily, though. There's a good document, because it's Meraki: https://documentation.meraki.com/zGeneral_Administration/Organizations_and_Networks/Combined_Dashboa...
