Hey, I’m trying to configure Adaptive Policy. Under the Adaptive Policy Group, I see Policy Object Binding. When I try to add a previously created policy object, I get an Invalid Input error.What is the correct type of object to use here?
Solved! Go to solution.
I’ve identified the issue. Previously, the Adaptive Policy object wasn’t available, but now I can select it, and it’s working as expected.
Hey ,Adaptive Policy Configuration Guide Adaptive Policy Overview
Is IT a network object?
Yes
Could you show us a screenshot of that object?
I notice you are creating a group call IT, the same as your network object. What happens if you make the names different (taking a guess here)?
Hey Philip, I change Network to IT-NET and GROUP to IT-GRP, and same issue...
Thank you
