Viewing the clients connected to a switch
ITDAN1
Just browsing
Every time I go into my Meraki dashboard and click on a switch it displays ever single client on my network.
Currently have 16 switches and if I choose 1 of the 48 port switches nd I scroll down, it displays all 400 some odd clients on my network.
How do I change it so when I click on a switch it displays only the clients attached to that specific switch?
Thank you
When viewing the clients, you can click in the search box and choose connected to and pick the switch in question:
ITDAN1
Just browsing
Is there no way to view the clients connected to a specific switch when going to Switching>Switches then choosing a switch and seeing that switches specific clients?
The switches view uses the ARP table and the clients on other switches are visible on the ports that connect them.  You can sort by port and then ignore those, but why wouldn't you use the clients page to view clients?
ITDAN1
Just browsing
I want to be able to click on a switch and view all of the clients connected to that switch.
I'm fine with the client list being every client connected on the network.
