In doing some preliminary research on VLAN Profiles , the document last updated Jun 6, 2025, indicate VLAN profiles are supported on the following platforms and firmware versions under the Requirements, guidelines and limitations section:
MR20/30H/33/42/42E/52/53E/70/74/84
Curious if MR36s, MR46s and MR56s should also be included (perhaps just not documented accordingly)?
I’ve not yet enabled or tested anything - just doing some preliminary research for a possible solution.
