URL for API calls
URL for API calls
Is there a difference between using api.meraki.com vs dashboard.meraki.com when calling APIs?
Thanks in advance,
-Jerome
Accepted Solutions
Re: URL for API calls
Not that I have found.
4 REPLIES 4
The reason I ask is that when i do an 'nslookup' I get the following:
JJabson-mac:~ jjabson$ nslookup on dashboard.meraki.com
;; connection timed out; no servers could be reached
JJabson-mac:~ jjabson$ nslookup api.meraki.com
Server:		10.64.81.5
Address:	10.64.81.5#53
Non-authoritative answer:
api.meraki.com	canonical name = na.api.meraki.com.
na.api.meraki.com	canonical name = n6.meraki.com.
n6.meraki.com	canonical name = sdg339.meraki.com.
Address: 64.156.192.232
Sorry that was wrong, it does work with both.
Your dashboard instance works too.  ie: http://n###.meraki.com
