Template configuration with its Addressing&Vlan
Ezzatcs
now I'm trying to create a templet and bind a network to it to push my configuration to all networks from one place. in my case, we have a multi-site with Meraki appliances, and we need these sites to have a different submit.
for example:
location x with 192.168.5.0/24
location y with 192.168.10.0/24
location z with 192.168.10.0/24 and so on.
With my template in my meraki Vlan, I create for each site a Vlan in my template with its submit and assign each network(site) in DHCB to its submit to have an IP. But when I connect the device to this network (Site) don't get an IP from this submit.1.png
Kindly help me in this point to make each site have its submit and I can apply configuration from a template like group policies to all networks. feel free to suggest a new way to achieve my goals or configure my template in the right way.
You need to create a single template with a supernet that contains all possible site subnets.  You must enable VLANs in the template.  Then you can use the "unique IP addressing" option, so each site will be automatically given a unique subnet.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
When you bind a new network to the template Meraki will automatically give it a subnet from the supernet you assigned, however you can just go into the network and change this to some other subnet in the supernet that you would like to use.
1 Reply 1
