I have one network that does not show the System Manager on it. Is there a way to add System Manager without having to re-create the network? BTW we have licenses for System Manager.
Solved! Go to solution.
I'm not 100% sure which will be the quickest or easiest way to do this.
One way is to create a new seperate Systems Manager network, and then combine it with an existing network.
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Combined_Dashboar...
That worked perfectly. Created a new System Manager network and then combined the two networks with no issues.
