Brandon, thanks for this and I'll have a read, but I think I have come to the same conclusion as you guys that from Meraki kit, it cant be done, but using either a local collector and then via TLS or keeping it on-net and using vpn tunnels would work.
I'll leave this open for a couple of days, just to see if anyone else has any thoughts
-Gary
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
