- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Removing unrequired network menu items
I've created two new networks under the same organization, one of them has:
- 'Network-wide'
- 'Security and SD WAN'
- 'Switching'
- 'Wireless'
- 'Insight'
- 'Organization'
the newer one has the same as above but also:
- Camera
- Cellular Gateway
I'm almost certain I created them both exactly the same way, no template, no cloning, just created a new 'combined' one and gave it a name.
Any idea why they've come out different? and more importantly, is there any way i can remove the menus i don't need? in this case the cellular gateway/Camera?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you create a network and don't assign any devices, you will see all of the menu items. That way you can preconfigure the network.
Once you assign devices to the network, only relevant menu items will remain and the others will disappear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thankyou Brash. That adds up as one of them I've just recently added some switches and APs to. This is what happens when you step away from deployments for a while! knew it would be something simple 🙂
Thanks Again.
