RIWAL Meraki Device Status [EOS(D)/EOS(D)]
MohanYadav
We already have the list of devices that are going to end support and do i need to procure new devices for the latest features and security. or else can use existing device as usual along same feature & security. in short if i used EOS meraki deviec that will work as given all feature or not?
1 Reply 1
Depending on the model, it will not update to the new versions, meaning it will not be possible to use any features that come with the new versions.
