Problem with adding switch to Meraki Dashborad
Jacek
Just browsing
I have a problem when I try to add C9200 switch to Meraki Dashborad.
IOS version 17.6.3.
Dna-essentials is also active.
We using tacacs to authenticate.
aaa new-model is enable.
Thank you in advance.
7 Replies 7
Check It:
https://blogs.cisco.com/networking/your-network-your-way-a-journey-to-full-cloud-management-of-cisco...
I saw it.
And in my opinion we meet the requirements which can find here: Cloud Monitoring for Catalyst Onboarding - Cisco Meraki
Have you tried the latest stable version?
Jacek
Just browsing
This is what I have, so in my opionion think we meet the requirements.
But use RADIUS, maybe here is the problem?
Are any chances to configure with active RADIUS?
No, it's not supported, you have to create a local account.
Ok, but while radius is active is it impossible to login as a local user.
have you tried it?
  • If command authorization is used (via "aaa authorization commands <level> ..."), authorization commands will be added to the cloud connection VTY line: authorization commands <level> MERAKI, where <level> is 0-15 inclusive.
