We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I have an SSID setup only for DEP Enrolled / Supervised devices.
Does anyone know if I could set up an SSID to only allow System Manager clients to use? I want to block all other connectivity.
Thank you,Peter James
Solved! Go to solution.
Edit the SSID properties. Under "Splash Page" select "Systems Manager Sentry enrollment ". Under "Systems Manager Sentry enrollment" select "Strict".
