Organization > Summary Report: MX showing negative 476GB data use?
RWelch
Any idea how/why the MX105 is showing negative data use?  I've used Meraki since 2016 and never seen this.
MX18.211.3
Thank you.
This is a known issue from the release notes:
  • Due to an issue under investigation MX75, MX85, MX95, MX105, MX250, and MX450 appliances may report an erroneous spike in network traffic usage
I'm guessing it can go either way, or you are seeing a first attempt at a fix!
1 Reply 1
