Need suggestion for maintenance report
I need to create a preventive maintenance report for meraki devices, but in meraki we can't find any hardware utilization.
Maybe all of you can give a suggestion what is a useful information from the dashboard which i can input to the report.
I think summary report from meraki is more useful for end user.
5 REPLIES 5
Re: Need suggestion for maintenance report
I agree. Stats that other vendors usually have available aren't available on Meraki:
  • CPU usage
  • Memory usage
  • temperature
On top of that what is available... I'd monitor the redundant power supplies. And also keep an eye on (redundant) links that might be experiencing issues, whether that be from a throughput perspective or from a reliability perspective. Same for the uptime of the devices: are devices going offline for no reason?
A slightly more detailed report would be useful over a 30 day period though.
To show utilisation, WAN, CPU etc - but its not really the Meraki way
On a deeper inspection I found its actually a lot more helpful than I thought. Some detailed information here
Hi All,
Thanks for the suggestion, i appreciate all suggestion from all of you
Go to "Organisation/Summary Report".  Make sure you have "Entire Organisation" selected.
The specific device utilisation reports are down the bottom left.
