Meraki logging by severity to SIEM
Juha_S
I would like to ask whether it is possible to raise or extend the log severity level on Meraki MS120 series switches in order to create alert profiles in our SIEM system based on severity levels. At the moment, the switches only appear to log events at the “Information” level.
If increasing the log level is not supported, is it possible to utilize the predefined alert profiles available on the Meraki side and integrate those with our SIEM system?
We are trying to setup syslog function for ManageEngine360 siem.
Thank you!
1 Reply 1
Unfortunately, MS120 switches do not support customization of syslog severity levels. They only send Event Log messages, and these are typically logged at the “Informational” level.
Syslog Server Overview and Configuration - Cisco Meraki Documentation
The Dashboard allows you to configure alert profiles for various events (e.g., port down, switch offline, high CPU).
And you can send these alerts via email or webhook. You can then integrate these alerts with your SIEM, either by forwarding alert emails to a monitored mailbox that your SIEM ingests, or by using webhooks to send alerts to a custom endpoint that your SIEM can analyze.
