Meraki MAC address sheets.
GuiBertinato
Hi, i'm with a trouble, i want to get all the MAC addresses logged and separate for time, to put in a sheet, is there any way to make this smarther than i think?
VivekT
Hi
Are you asking for all clients machines which is behind you Meraki infra ? If yes
You can follow the details as per below screenshot
Network wide----Client
VivekT
You can also use API to fetch required info in following ways.
  • Meraki's API allows you to retrieve client information, including MAC addresses, along with associated data like connection times, usage, and more.
  • You can filter the data based on the timestamp for each device to categorize the MAC addresses by the time or period you're interested in.
  • You can export this data into a CSV file (or directly into an Excel sheet if you prefer) using Python, which can then be used for analysis.
GuiBertinato
I would like all MAC addresses recognized by the Meraki MR to feed into a big data system in order to analyze locations with higher user frequency, times, etc.
From network-wide/clients, use the download option:
