Meraki Equipment Reset - Unclaimed
alarson011
I am still new to Meraki Equipment. I obtained such equipment from an upstream customer who is concerned about data on it (Meraki MX80 specifically) and wanted to know if it was possible, for someone to bring that unit back to their site and "hack" into their network.
To my knowledge, they can be reset with the reset button and unclaimed from the Meraki Dashboard. Is that sufficient enough?
Before these questions appear, please understand I'm not asking about these routes;
  1. I know Cisco has a pick up and perform a secure-destruction for free.
  2. I understand physically destroying the unit also works.
My knowledge stems from this as well; https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Cisco_Meraki_Devices_p...
rhbirkelund
Meraki is Cloud Managed network. This implies that all configuration in general lies in the Cloud.
If the device has been factory reset, all configuration on the device is removed, and the device will attempt to contact the Cloud, inorder to download a configuration for the device. Now, if the device is also unclaimed, there will be no configuration for the device in the Cloud.
In my opinion, factory reset, and unclaim should be sufficient. The device won't be able to build a VPN tunnel into the Customers network.
All code is provided as is. Responsibility for Code execution is solely your own.
2 REPLIES 2
Secure Device Connectivity
For devices to communicate with the cloud, Meraki leverages a proprietary lightweight encrypted tunnel using AES256 encryption while management data is in transit. Within the tunnel itself, Meraki leverages HTTPS and protocol buffers for a secure and efficient solution, limited to 1 kbps per device when the device is not being actively managed.
rhbirkelund
