Is there a way to get Meraki Stencils in a format other than VSS? I use Lucidchart for diagrams and there is currently a bug in their platform where the VSS file cannot be properly imported. Is it possible to get SVG or PNG format?
Thanks!
Solved! Go to solution.
https://meraki.cisco.com/lib/cisco_meraki_topology_icons.zip
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
https://www.cisco.com/c/dam/assets/prod/visio/visio/security-cisco-meraki.zip
https://meraki.cisco.com/product-collateral/cisco-meraki-visio-stencils/?file
Thanks, but this is VSS format only. I'm looking for SVG or PNG. I don't have Visio so I cannot convert a VSS file.
Check the last one that I sent.
That second post is helpful. Thank you!
