Meraki Data Connector in Sentinel
TimTim
Currently trying to connect the REST API data connector. Have the Ord ID and API Key but when I hit connect within Sentinel the deployment just starts and does nothing.
Any hints?
Many thanks,
Tim
5 Replies 5
Have you checked to see if there are any rules that could be blocking the firewall? And what about the logs, have you checked to see if there are any errors?
Take a look at this discussion, maybe it can help you.
Meraki Rest API information is out of date and failing to connect · Issue #11248 · Azure/Azure-Senti...
TimTim
Getting the following error now:
Deployment Failed At least one resource deployment operation failed. Please list deployment operations for details. Please see https://aka.ms/arm-deployment-operations for usage details.
{ "error": { "code": "BadRequest", "message": "Connectivity check failed. ConnectorId: CiscoMerakiIDSRequest, Status code:Forbidden, Message:Call failed with status code 403 (Forbidden): GET https://api.meraki.com/api/v1/
In your place I would confirm that API access is enabled in Meraki, that the API key and organization ID are correct and also test the API manually to isolate the problem.
TimTim
Is there a separate step to enable API access, or is that done once a key is generated?
