Meraki-Dashboard-TV-NOC-Mode-Local-Host-Web-Portal
RamonSolis
Ever wish the Cisco Meraki Dashboard had a true NOC “TV Mode”?
Imagine a dark-mode, wall-display view that:
• shows real-time network health at a glance
• is shareable with stakeholders and IT directors
• stays secure with MFA authentication
• uses a read-only Meraki API key (visibility without risking changes)
I’ve been working on a lightweight Flask-based Meraki dashboard built specifically for NOCs and wall-mounted displays—and it’s available as an open-source project on my GitHub.
Would your team use something like this as an open-source solution, or do you already have a “TV screen” network monitoring setup in place?
#CiscoMeraki #Meraki #NOC #NetworkOperations #Flask #NetOps #CyberSecurity #ITLeadership
https://github.com/rasolis610/Meraki-Dashboard-TV-NOC-Mode-Local-Host-Web-Portal/tree/main
A lightweight, dark-mode Flask web application designed specifically for Network Operations Centers (NOCs) and wall-mounted TV displays. This application connects to the Cisco Meraki API to provide a real-time, high-visibility dashboard of your network infrastructure, builtin with MFA.Meraki Dashboard TV Mode flowchart.pngMeraki DashboardTV Mode.gif
I don't think so, in most cases we use a external server running Zabbix for monitor the networks.
BHC_RESORTS
The snake feature is super distracting.
BHC Resorts IT Department
RamonSolis
Great observation.
I think this is a great idea.  I like it.
