Meraki - All Networks - Uplink (Tx/Rx Utilization report in %)
karthikD
Meraki Dashboard - All Networks - How to pull Uplink (Tx/Rx Utilization report in %)
Getting utilization rate per WAN connection is doable for individual site (we still have to calculate %utilization). It’s a manual process at this time and will require more time.
The navigation path on Dashboard is Organization à VPN status. It will not show % utilization that we expect to see
1 REPLY 1
The MX doesn't necessairly now the WAN circuit size, so it can't report a percentage.
You could consider using SNMP to pull the throughput, use the WAN size which you know, and calculating the percentage.  A bit painfull.
