- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Is the PSU on the MX105 hot swappable?
I have a PSU to replace (MA-PWR-150WAC) on a MX105, but cannot find if this PSU is hot-swappable.
Other MX's are listed with hot-swappable PSU's but I cannot find a mention if it specifically is or isn't.
Any help would be great. Documentation is here - MX95/MX105 Series Hardware Installation Guide - Cisco Meraki Documentation
Solved! Go to solution.
- Labels:
Inventory
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Meraki product team have advised that MXs with dual power supplied support hot swapping, and to ensure the swap is done during a maintenance window - solved
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I suggest you open a support case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@LiamWestlake I would be amazed if it was not as every other twin modular power supply Cisco device I have ever used is. If you only have one power supply at the moment make sure you wait until you can see the new one inserted and live in the second slot before touching the first slot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Was thinking the same thing, but the fact that it doesn't confirm it in the documentation makes me more paranoid.
Will see what Meraki comes back with.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It is listed as an orderable accessory. There would not be any point to this if you couldn't install it. If you can install it, you can replace it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Was referring to the ability to swap the PSU while the FW was still running, rather than installing it at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
