I would like to replace the Cisco Meraki logo with a company logo in the upper left hand corner of the dashboard if possible.
Solved! Go to Solution.
The document states: „Dashboard branding options are only available to qualified Managed Service Providers. Please contact Cisco Meraki Support to check eligibility“
Thank you for sending this over. I have seen this document but I do not have the Branding option in my organization settings. Is there something I need to do in order to have that option?
As far as I know, I am not a Managed Service provider. Oh well, no big deal.
Thank you for all of your replies.
I spoke with support and I am not eligible to have this option enabled.
That is a shame, you don't as you don't get..
But in this case that hasn't worked!
I made a wish. Maybe it will be granted. 🤞
